I�ve discovered following apps doesn�t work:
FaveWarp
Camcoder PRO
CameraFX
Doom Sounds (surprise, surprise, doesn�t work on anything but the 7650?)
Apps that Work/Don't work on 7610
I think it's safe to say that any app which uses the camera is not going to work.
Philips camcorder
Photographer
Etc.
So far all other apps that's advertised as 6600 compatible has worked for me.
SMSextender
MGS Pool2
RescoViewer
UltraMP3
Oplayer3
And the nice people that created these progs have all kindly given me new reg codes to get these working on my new phone!! 😊
OpenBit are working on a 7610 version of Photographer too.
Will
willbrady wrote:I think it's safe to say that any app which uses the camera is not going to work.Philips camcorder
Photographer
Etc.So far all other apps that's advertised as 6600 compatible has worked for me.
SMSextender
MGS Pool2
RescoViewer
UltraMP3
Oplayer3And the nice people that created these progs have all kindly given me new reg codes to get these working on my new phone!! 😊
Will
so the 5 apps listed by u work just fine without any editing?
Any links? 😊
Doom sounds work on the N-Gage as for applications,try the shop: http://www.allaboutsymbian.com/shop/
You should check out the List of working/non working apps in the 6600 forum.Since the 6600 and 7610 both run on Series 60 2.x and Symbian 7.0s
try ETI's Cam Pro 😊
My friend got it to work on his 7610...
Singapore wrote:try ETI's Cam Pro 😊My friend got it to work on his 7610...
Well, that app sucks a bit too much :P
Cbswe wrote:Well, that app sucks a bit too much :P
like???
Why bother with a camcorder app?
The built in 1 does extended recording, 10 mins is enough for anything.
Including for me a home porno 😊
Job wrote:Why bother with a camcorder app?
:top:
with audio?
Singapore wrote:so the 5 apps listed by u work just fine without any editing?
Any links? 😊
hey...
ive got UltraMP3 and MVR's Pool2 which are working on my 7610.
pm me if u want it, k.
Photographer
SMSextender
MGS Pool2
RescoViewer
UltraMP3
Will
UltraMP3 works fine, BUT it won't stop playing when there is an incoming call. It just stutter and hiccough, but if you are not careful you might miss a call. You have to turn it off to receive your call properly.
Do you have such an experience?
Photographer
SMSextender
MGS Pool2
RescoViewer
UltraMP3
Will
sorry i post one more reply cos i juz reg & nt really know how to post and reply it wrongly so i post one more in case u dun understand the above one.
Just wanna ask u where u get those reg codes? Any recommend?
Yes,try the shop: http://www.allaboutsymbian.com/shop/
cameraFx v2, and camcoder pro (4 6600) both work on the 7610...theoretically, everything that works on the 66, should work on the 7610...but it isnt quite that simple is it..lol...
