6600 sound probelms
2 replies · 1,593 views · Started 14 June 2004
hi ive got a 2.5mm to 3.5mm plug for using my headphones for mp3 and movies , only problem is that the sound still comes out the side of the phone , and i get the error ' enhancment not supported ' then it stops working what do i do ?
tomk_bucks wrote:hi ive got a 2.5mm to 3.5mm plug for using my headphones for mp3 and movies , only problem is that the sound still comes out the side of the phone , and i get the error ' enhancment not supported ' then it stops working what do i do ?
The jack plug that you are using is stereo and the phone is mono,thats why it is not supported.
hehe i believe that u r using the ngage adaptor right? it doesn't work that way, u can see the 2.5mm pin actually have 2 stripes only, as for the mobile phone , the pin should have 3 black stripes.
i have mine and it's working fine but i don't lile the sound of it. MONO. 😞
