Recording & Playing back
15 replies · 2,779 views · Started 24 September 2002
hey all! i know i'm askingt alot of questions 😮ops:
when i RECORD a song and play it back.. it played faster than the original song. i don't know why! i checked the mic and the speaker and they are working well ( btw, how can i test them? 😃 ).. any idea??
thanks
hi again..
when i record a song for example, the timer in the laptop is, lets say 40 seconds, but in the comm 30 seconds, when i play back, it's 30 seconds but the acutual is 4o seconds. it's playing faster than the regular.
help help help
Regards
Try converting the wav file you recorded with Multi Media Convertor from Nokia. It could be your laptop uses a different codec.
thanks for replying Dazler.
u didn't get my point man.
i'm using the Voice Recorder in the 9210i.
try it. start a stopwatch at the same time u start recording.
will they finish together??
here the timer is 1 min and the Recorder timer is 50 secs :-?
plz guys.. try it on your comm and reply me..
thanks
what should i do then?
it's a software problem, right? i've removed all the programs on my comm. and deleted all the sound files. and still the same.
from where can i get a new recorder?? essential one.
The original recorder sis file can be found at www.nokia.com
Do you really hear it play faster?
yes Dazler..
i don't know why! maybe after removing the MultiMedia player something happened.
i can't find the original recorder man. can u give me the exact url please.
thanks
Forgot, 9210i software isn't downloadable from nokia.
you could try the recorder for the nokia 9210 @ 4.13.
Get it here
last qeustion Dazler.. sorry for disturbig u 😮ops:
if i installed the recorder, it will replace it with mine?? or it will install a new one and i can remove it?
thanks alot
how can i make back up? i'm still biggener you know 😮ops:
i just want to back up the recorder
Easiest way is to backup the entire c: .
Otherwise copying the recorder files to pc will do fine 2.
Can't tell you which files exactly, I'll try to find out if you can't.
Don't you have a cd with your phone? The sis file should be on there normally.
Dear Dazler,
i've installed the Recorder again. but the same problem. i bought a 8MB mmc. and installed it. then everything works fine.
i think the problem from the -Max Length Available- becuase when it's a small memory it's easier to calculate. what do u think.
btw, i'm using a 64MB mmc , when i recored a Compressed WAV file, it works well. but in Normal as i told u before.
Thanks a million.
Could be, just tried it with the default folder set to mmc, it works better now.
When I selected the communicator it always stopped, recorded, stopped, recorded. So fucking strange (the file it self was normal). Any how I use a 32mb mmc and had about 9 minutes left and it seemed to do allright.
Your probem could be caused by the big size of the mmc. This will also explain why it works in compress mode. Compress mode is lower sound quality which means lesser cpu to convert, which means more to calculate the massive size.
The recorder doesn't seem to be the most state of the art program 😉
