Bluetooth Problem
1 replies · 1,085 views · Started 14 June 2004
I have the nokia 6600 and have installed the PC suite software and the software for my BlueTooth Dongle Adapter Adaptor. I have paired the devices already and set up the ports on the pc suite. I try to connect via serial port but when i do so i get the error message that you are supposed to get, but then when i click ok, everything including the taskbar disapears for 10 seconds and when it reapears, the icon for the connection manager for pcsuite is gone and no connection is made. Sorry if this has asked before but can anybody help me?
Cheese Toastie wrote:I have the nokia 6600 and have installed the PC suite software and the software for my BlueTooth Dongle Adapter Adaptor. I have paired the devices already and set up the ports on the pc suite. I try to connect via serial port but when i do so i get the error message that you are supposed to get, but then when i click ok, everything including the taskbar disapears for 10 seconds and when it reapears, the icon for the connection manager for pcsuite is gone and no connection is made. Sorry if this has asked before but can anybody help me?
How much ram have you got???
I had a similar problem with 256mb,when lots of programs open (about 5 i had),it seems there was not enough ram to keep windows explorer running properly as well as all the other programs and a bt connection, close the error message box instead of clicking "ok" as this error message makes no difference at all and will still connect after.
For more info,search the forum as there is LOADS on bt issues.
