I have my N3650 with Kingston 128MB Card.
I have installed all the program's on the MMC,
I relocated the messaging folder on the MMC,
Cleared all the pictures from the Phone memory,
all the melodies and extra files.
But still some program's report Out of memory error.
I have 1,98MB free memory on the phone.
How can I free some more memory on the phone?
I have over 80MB free on the card.
Martin Max wrote:I have my N3650 with Kingston 128MB Card.
all the melodies and extra files.But still some program's report Out of memory error.
If you don't have very important data on phone or MMC u can format your phone ...... all u have to do is : in stand-by mode u can press *#7370# ..and you'll be asked if you want to format your phone ......u need pin2.....and wait .!!!!!... but you have to do this AFTER YOU HAVE FORMAT YOUR MMC CARD..!!!!!
after that you can install everyting back on your MMC
panainte_b wrote:If you don't have very important data on phone or MMC u can format your phone ...... all u have to do is : in stand-by mode u can press *#7370# ..and you'll be asked if you want to format your phone ......u need pin2.....and wait .!!!!!... but you have to do this AFTER YOU HAVE FORMAT YOUR MMC CARD..!!!!!
You advice is not resonable.The 3650 is low on RAM so he can close up some applications running in the background,i don't believe that formating will help.The 1,98MB free memory is storage not RAM.Thread closed,search the forums.
Also you use the lock code, not PIN2.
