Themes on 7610...
1 replies · 3,580 views · Started 14 June 2004
Can someone please telll me how* to send themes *.sis from my PC to the 7610
using the USB cable?
Where are the themes supost to go?
Connect the 7610 via USB & then connect via connection manager in control panel. Once this is done the just simply go to application installer and transfer the *.sis file and then hay presto! The file will then be picked and unpacked to the phone.
If you need help just look for help using Pc Suite V6.
