What time is it???
2 replies · 1,293 views · Started 15 June 2004
Gosh darned it. For some reason the clock on my P900 changes by an hour every now and then......??
About every three days I check the time and it can be either an hour fast, or an hour slow.
What's going on?!?!?!
Are you synchronizing your phone with a PC? If so, what's the time on the PC?
If the P900 supports getting the date/time from the network (I don't have one, so I don't know), have you enabled it (and is the feature enabled and working properly on your operator's network)?
