Guys,
In my previous 9110 I was able to view the log file and choose to create New Card if that number was not in my adress book.
Can this be don in 9210 or is a Nokia impovement? 😮ops:
Thank You
The specialBoy is not so Special or 2Special, so don't worry :evil:
go to the log, use arrows to go to the needed entry.
Press enter or CBA1
And you now have the choice to add it to contacts as well as copying the number
When I press enter, nothing hapens.
Did you encounter such behaviour?
Does the 'USE' text show up next to the cba button 1? (cba=keys on the side of the screen)
be sure to have selected the entry.
I press the Use key related on the right of the screen, first button from up to down. 😃
Yes of course. Eighter use or enter doen not affect with anything.
