help with nokia 6600
2 replies · 964 views · Started 15 June 2004
how do you lock(with lock I mean that it has to be opened with a password) your the images you made
jigga wrote:how do you lock(with lock I mean that it has to be opened with a password) your the images you made
You cant mate,
The best i could come up with is a bit of a mission.
Here goes....
1.Swap message memory from whatever you are using (Menu/messaging/options/settings/other/memory in use).
3.Create an mms with the image and close (saves to drafts).
4.Delete the original image in the gallery.
5.Switch Memory in use back to the one you use.
6.Enjoy images that are (not password protected) but pretty well hidden.
Images may well be resized for mms??? But it depends on your priorities.
Hi there,
You can always download Handy PhotoSafe which can pasword protect your
XXX images 😉
Gef
