I want to use my 9210 as a modem for my laptop.
Does anybody know how to do that ??
Setup 9210 as modem for laptop
Install modem drivers from your cd or forum.nokia.com to your laptop and activate "fax-modem" from 9210...
I have done that but when i try to make a connection my laptop says that the remote server does not answer.
When i look in my phone log there is no entry of a datacall so i have the feeling that there is no phonenumber called at all.
Take a look to faxmodem settings in 9210.. Go to > OS > Windows2000 > Yes
Have you done that?
Yes those settings i have.
Now i get an error message (on my laptop) "Could not setup a PPP connection with remote server" so i think our RAS server does not support this function.
However i think this is strange because i can use my 9210's internet browser with the same dailup settings as on my laptop.
I think i go and look for an other provider and try there if i could use my 9210.
Once i have same kind problem cos i use High Speed and my other ISP dont support that very well. I change ISP and now i can connect via v120 HSCSD modem drivers.
Do you use HSCSD? Have you tried slowest drivers?
I used "analog 9600" maybe i should use "ISDN v120" maybe that will work.
What are your other settings ??
in windows, i have default settings. (i only need my service providers phone number)
Have you tried other providers yet?
