Please can someone tell me where (file structure wise) the tumbnail images for contacts are stored on the phone.
There are stored in:
C:\Nokia\Images_tn\
Hope this helps.
Hate to spoil the party, but they are not there. I have no images in this folder (I deleted them), but the when i go to contacts, all my contact images are still there.
The phone saves a copy of the image somewhere - but where?
[quote="Lydecker"]Hate to spoil the party, but they are not there. I have no images in this folder (I deleted them), but the when i go to contacts, all my contact images are still there.
Thanks[/quote]
Perhaps it saves a copy of the image in your contacts. So your Contacts will be 1-2kb bigger for each entry with a TN
They are originaly kept in the folder I mentioned
Hence the name IMAGES_TN, TN as in ThumbNail
No - My IMAGES_TN directory is empty.
THE IMAGES STILL APPEAR WHEN SOMEONE CALLS me on the phone.
The thumbnails for the Imaging application are stored in C:\Nokia\Images_Tn\ but the thumbnais for contacts are stored in the contacts database as part of the contacts data, just as it is with the 9200 series.
Images attached to contacts, which are viewable by selecting a contact and moving the joystick to the right, are not stored in the database but are loaded from the Images folder when required. That's why when you delete an image, the large view vanished from a Contact, but the thumbnail stays where it is.
To delete the contact's thumbnail, select the contact, Edit and then select 'Remove Thumbail'.
Sorry I mis-read your answer, See my edited possible answer.
So a 2Kb (average) image is stored in my DataBase when I assign an image to a contact?
How many images do you have in your contacts? And how many (estimated) contacts do you have in your address book.
Id say 30 contacts in the address book. 25 of which have a image attached.
Why?
What size is your Contacts in KB?
My Contacts in C:\system\Data is 113Kb
My Contacts under App. Manager is 110Kb
To answer you question, Yes it does store a copy of the picture in your contacts. I have around 100 contacts, none of which have pictures attached. It takes up 53kb of space.
You have less contacts than me but more than double the space.
Excellent - thanks for clearing this up!
Thank you
Sounds like a FAQ to me 😊
Rafe
I'll add it to the list! 😃
