I got my new 6600 a few weeks ago and i installed psiloc irremote 1.41.
The software is trial i know but when the trial period ended i uninstalled it and tryied to install the newer version 1.45.Unfortunately when i start the application it says that 'the trial period is over' again!!
Does anyone know a work around??
Psiloc Irremote uninstall!!!
aries9_gr wrote:I got my new 6600 a few weeks ago and i installed psiloc irremote 1.41.
first of all the version of IR remote does not matter when it comes to installing/uninstalling. buy the software and get the license. that is the solution. or if you have a utility like HandyFile and you ur way throught the fons system files then maybe you can delete that specific file form IR remote.
psyph3r wrote:first of all the version of IR remote does not matter when it comes to installing/uninstalling. buy the software and get the license. that is the solution. or if you have a utility like HandyFile and you ur way throught the fons system files then maybe you can delete that specific file form IR remote.
I know but the problem is that specific file......
i searched through all the drives and couldnt find anything exept ''epsiloc.mdm'' which is an image nothing else........
