hi all
I've just learnt how to transfer files between 7650 to my notebook .. using IR. I got this cute animated gif inside the image folder. But when I put it as the background pic, it does animate!
May i know how to do it?
thanks
hi all
thanks
you cant... use a sreen saver prog and put it as s saver :P
hi be_cool
so.. how do i go about using a screen saver pgm to change it to a saver? Eg. which software? Brief steps? I thought the screensaver on 7650 only allows text or date/time?
It will only go through one animation cycle if that and then stop ... However if you go to www.psiloc.com and try Screen Saver for 7650 you will be able to use it as your screensaver ... This does use alot of battery depending on the speed of the animation etc etc etc...
BUT like i say it will only go through one cycle if that ( It will play once however if you open it up in IMAGES, also it may take a couple of seconds to display as your phone loads it all first ! )
hope this helps
