I want to get a bluetooth handsfree ?
Is anyone using it ,if so can you tell how good it works and which one is the best etc etc .
Thanks in advance.
Thanks in advance.
hmm .. same question .. any good BT headset names .. other than nokia .. compatible for 3650 n 3660 ...
I actually sell phones for T-Mobile, Boost, and Nextel and we sell a Motorolla Bluetooth Wireless Handsfree that is compatible with any device that is Bluetooth capable. Sounds great too! It runs $99.99 US funds.
deepak_vs24 wrote:I want to get a bluetooth handsfree ?
Is anyone using it ,if so can you tell how good it works and which one is the best etc etc .Thanks in advance.
I just got a scala-500 BT headset from cardo, it works great.
However, my 3650 handset does not ring when paired with headset which is a very bad design for 3650. Called nokia and they said it was designed to do so 😡
I use the Motorola HS810 I bought at radio shack (last minute purchase. It was an emergency!) And I'm quite happy with the little device. I wear it pretty much all the time and the volume sounds great even in my loud car.
Just my suggestion. 😊
The thing about this Bluetooth Wireless Handsfree is that it's so small. Well, you can guess what happened to mine. It is now lost! When I bought it, it is worth as good as a New Mobile Phone and I lost it. But now, it's pretty cheap.
Tee Horng Hean
Malaysia
I use the Nokia HS-11W. I have found that it works pretty well. I don't like that the phone doesn't ring, however if you are connected to the earpiece, then you don't really need to hear the phone ring, because it rings through the earpiece.
get jabra bt250 for 3650 it is by far the best headset for the 3650. it works perfectly with it. you can even dial from it unlike other heatsets.
