I have converted some .mpg's into .3gp video files using Nokia's very useful Multimedia Converter 2.0.
I have then bluetoothed these to my phone and I can view them using Real Player, which works perfectly...
...however I don't seem to be able to find away of moving the .3gp files onto the 32MB memory card. The only option I have is to keep them in "My Folders" which is part of the phones memory. (which is nearly full)
Does anyone know a way of moving these files about the phone and hopefully onto the memory card??
Any help is greatly appreciated.
GVX
GVX wrote:I have converted some .mpg's into .3gp video files using Nokia's very useful Multimedia Converter 2.0.I have then bluetoothed these to my phone and I can view them using Real Player, which works perfectly...
GVX
yeh so the vid is in ur inbox of the BT so wen u open it should giv u the option to save from here select MMC then save where ever. 😊
Or use FExplore and move it.
GVX
how did you do it,i tried to convert my .MPEG files to .3gp in the Nokia multimedia converter but it says unsupported format.whats the difference with mpg and mpeg?is there other program that would do this?
BluePhoenix wrote:Or use FExplore and move it.
Thanks...great little app that worked like a treat...cherz!
geishaslut wrote:how did you do it,i tried to convert my .MPEG files to .3gp in the Nokia multimedia converter but it says unsupported format.whats the difference with mpg and mpeg?is there other program that would do this?
Not sure what your doing wrong? There are various types of .mpg files so maybe it doesn't support it.
Try dl the latest one from here http://www.forum.nokia.com/main/0,,034-63,00.html
Cherz
GVX
