After a lot of Beta testing, PsiLOC+ have released their long awaited Screensaver application.
Manhy of the features will be familiar to those who have been installing the beta versions, but some other features may prove new to everyone. The available screensavers are;
[list]
Text - Normal text screensaver
Date & Time - The normal Date & Time screensaver
Analogue Clock - Bouncing clock where you tell the time looking at hands 😃
Digital Clock - Bouncing clock, but no hands.
Big Clock - A clock that's like really huge and fills the screen!
Spotlight - Black screen with a bouncing circle that reveals bits of the screen at a time
Animation - Display an Animated GIF of your choice
Slide SHow - Display images from the imaging root or one of the folders in a slideshow
Starfield - Speeding through space!
Explosion - Kind of like the classic fireworks display, only different.
Long text - Kind of like the marquee screensave on Microshaft Window$
[/list:u].
There are options to switch off the screensaver after a set amount of time (to save battery power since some options drain power like its going out of fashion), and to activate the screensaver at once.
At only $9.95, it's not bad, but you can have a trial first if you want. Just click here and do your funky thang!
