I downloaded the FExplorer.sis file, and now I want to put in my MMC (i can view/delete/edit/add the data in my MMC). My MMC is arranged like this -
-Backup
-Images
-Sounds
-System
-Apps
-MAil
-MIDIlet
-data
-Videos
can you all please tell me where to keep my .SIS file?!
rohit
Help!
Put it anywhere you like. I usually just drop .sis files in the top/root directory, install them and then delete the .sis (because it is no longer required after installation).
N/A wrote:Put it anywhere you like. I usually just drop .sis files in the top/root directory, install them and then delete the .sis (because it is no longer required after installation).
But he wont be able to navigate through it if he goes to images because what it will do is just show all images. He doesnt have a file manager yet and would like to install it.
Maybe what you would want to do is fool the phone into thinking that u have a new message. I hope ur using the mmc as the default memory for messages. Locate the mail folder then drag and drop the sis file somewhere there, (do some experimenting because i dont know if this will work) then open your inbox, if lucky it would just be there as a message.
Tell me if this works.
