still need help!
3 replies · 1,163 views · Started 17 June 2004
whoever said to drop the .sis file in the root directory of the MMC card... no offence, but when I open App. Manager then it says "(no data)"! MY phone can't find the .sis file, it seems! can you please help me!
I will put the structure of the MMC card on my comp. again-
backup
images
sounds
system-apps,data,favourites,mail,MIDIets,midp.
videos
please help!!
rohit
Works on my N-Gage just fine that way; Manager locates the .sis file and runs it just fine & dandy.
In general, however, I just use PC Suite to install stuff, or send them via Bluetooth.
Hey Everyone! I got the .sis files on my phone, with the help of GhostDog�s advice� �Search in the forums��. That�s exactly what I did. I searched for �SIS Files�, and in one thread I discovered a program called �UNMakeSIS�, which you had to download (a very short download) from some site. Then, it opened the Fexplorer.sis file with UNMakeSIS on the computer and there was an option called �Extract files�, and I extracted my files to the MMC, and it worked on the phone! I had Fexplorer on the phone then. I tried doing the other .sis files the same way, but on the phone it said �System Error!�. So I took N/A�s idea of putting the .sis file in the root directory MMC and checking it with Fexplorer, and I installed the rest of the .sis files that way. I don�t know what site I downloaded �UNMakeSIS� from, but you can search the forum for �SIS Files� to find it!
Rohit
P.S.- Thanks Kamlayam, but it didn�t work in the Mail folder.
