Having recently purchased one of these babies, i naturally have a couple of queries.
1.I have N-Gage games on my hard drive, where do i put them?
2.Can i use my shared memory like i use my internal memory (like the same usage)?
Thanks a lot guys 😊
1.) You can transfer them to a MMC card inside the N-Gage via the USB cable, or either onto a MMC card or the 3.4 megs of internal memory via a Bluetooth connection. You should be able to install them using the N-Gage's basic functions, or with an outside program that you can also put on, such as FEExplorer.
2.) You can put an MMC in the N-Gage and use USB to transfer, or use a wireless Bluetooth connection to transfer to either an MMC, or the internal memory.
You CANNOT ACCESS the internal memory of the N-Gage unless you're using a Bluetooth connection.
Because its just that i keep getting the message please delete some sim data (i have txts coming through)how do i free up space on the sim, or make the gage use the mmc card for storing txts?
thanks
With the PC Suite program and a Bluetooth connection, you can determine where you want specific files to go, I.E., if you want a .txt on the internal memory OR the MMC card, you can choose.
If you're not using Bluetooth, you have to put everything on an MMC card, because it is the only thing that shows up when you connect the N-Gafe to your computer via the USB cable.
