Hi all.
I have noticed that the screen has a bright red dot on it now so im thinkg of contacting provider to see if they will replace it. My question is can all the data be copied of my existing 6600? I have seen the gold contacts under the batt and have been told its a usb connection. Can any one confirm this and if so how the hell do you use it.
With the copy part can "an image" be taken and placed back onto a different 6600 like what can be done with pc's and what software is needed.
Lee
ltodd2 wrote:Hi all.I have noticed that the screen has a bright red dot on it now so im thinkg of contacting provider to see if they will replace it. My question is can all the data be copied of my existing 6600? I have seen the gold contacts under the batt and have been told its a usb connection. Can any one confirm this and if so how the hell do you use it.
Lee
Back up your phone onto mmc and insert this into new phone,
Its in Memory (cant provide a full path as i have moved mine) /options/backup phone memory.
