Hi Rafe 😉 et. al.
I need help syncing my 6600 with my desktop computer. Although, only my laptop has Bluetooth. (Both are on a nework).
Is there any way to sync outlook accross the network?
Thanks....
Hi Rafe 😉 et. al.
Thanks....
The Remote Sync client can synchronize with a SyncML Server over the network. If you can find a SyncML Server for your desktop PC, and make it accessible on the Internet, and also make it work with Outlook, you could.
The SyncML Server products I'm aware of are for server-side solutions for companies or operators, but not for desktop use.
A cheaper option: Buy a Bluetooth or infrared adapter for your desktop PC, too.
GooGLe :: http://nicolas.bougues.net/syncml/
Don't know if this going to work , but I'm testing it this afternoon .
let me know if it works out!
Getting a system error ...
