Plz Plz Help Me Plz Plz
4 replies · 4,495 views · Started 18 June 2004
my 6600 jus keeps on switchin on and off automatically, it gets to the main menu then it just switches off and switches on again by itself, it does this like 3/4 times then the phone jus switches off like the phones switched off! what wrong with the fone???? cause i was in wap and i just switched off the fone jus to restart it and it keeps on switching on and off! PLZ PLZ HELP ME!!!!!!!!!
I've got it on anothere way .
The phone restars by his own , it starts , nokia logo comes on . Reboot .
He does that 3 or 4 times and then give up .
I have tooken it to a Nokia Service point and they repaired it for free .
Also have made a software upgrade ...
Vicky wrote:save ur important data and then
format the phone
if the prob repeats then do tell me.
hello i have nokia 6600 i m gettin prob with it
in my outbox folder a msg iz automatically created and it picks any number frm da list n send mms to that number though it dont send that .. it failed to send ... but set time to resend mms again
like Resned at 3:30
plz help wat i do
Killabyte wrote:my 6600 jus keeps on switchin on and off automatically, it gets t[B]o the main menu then it just switches off and switches on again by itself, it does this like 3/4 times [/B]then the phone jus switches off like the phones switched off! what wrong with the fone???? cause i was in wap and i just switched off the fone jus to restart it and it keeps on switching on and off! PLZ PLZ HELP ME!!!!!!!!!
Hello I think u should format ur phone hard with
green star 3 method you wil find in this site but be careful backup ur data first.
😎 😛cguru: 😛cguru: 😛cguru:
