I am after a program (which actually works on a nokia 6600) to be able to use msn messenger from my mobile.
Have tried IM+ which looks good, except refuses to connect to msn
Would greatly appreciate any other programs or tips
Cheers
Cheers
Many thanks for the program mate, again looks good 😊 except refuses to connect to msn. Could it be the network i am on? Its vodafone in the UK?
Cheers
I've heard and read that on some operators in certain countries (like T-Mobile in USA) a special internet subscription is required in order to get access to the internet.
It's a shame but if the same applies to you then you won't be able to connect I guess.
But if you do have internet access, billed or free, you should be able to use it.
Just select on the main screen the same access point as you use for opera or other internet apps (not the one you use for your wap browser!!).
Good luck,
or at least use MSN by a WAP-gateway
