How do you add jar applications to the Favourites folder?
4 replies · 2,221 views · Started 25 September 2002
Does anyone know how to do this?
I have installed WebViewer and would really like a link to it in the favourites folder, but can't see how I can do it.
Using SeleQ I can find the possibly, installed files in the following directory "c:\system\midp\Reqwireless Inc_09\untrusted\1_096\"
But none of these seem to be the startup file.
Any ideas? :-?
mmm... fraid it can't be done.. they have to be launched from the apps thing..
No, it must be possible. I can see why it's not easy, since it's an "untrusted" application, but there must be a way. Perhaps I need to write a little application to do it.
Any other ideas?
I have asked for this here some days ago and it seems there is no possibility indeed. Even with TaskManager (Psyloc) u can create shortcuts to any *.sis-program, but not to javas.
