I've just released version 0.1 of a free (GPLed) program that downloads and displays METAR weather reports on your phone. Its called "Weather" and you can get it at
http://badpint.org/weather
I'd really appreciate feedback and bug reports.
I have only tried it on my 6600 so I'd like to hear if it works ok on other Series 60 phones.
If anyone wants to contribute translations for other languages drop me an email too!
Thanks,
Justin
i saw PROXY settings into OPTIONS! does it work with wap connections?
it will rock 😉
cheerz
ohh.. doesnt work with my 7650 😞
It doesn't? what happens?
Does it install?
installs, of course!
the icon is the blue puzzle and i think that some of the APIs of 6600 are not working to 7660 😞
Hmm.... I don't think I'm using any 6600 only APIs :?
I'm not sure what to do now...
Thanks for trying anyway 😊
On the N-Gage it exists with a System Error.
Ok it seems that it doesn't work with v1.0 of Series 60 because it was built with the v2.0 SDK.
Hang on...
Ok... could someone try it now please ?
I did,it crashed with the same system error.Is your website updated with the latest build of weather?
Oops! 😃
I hadn't updated the .pkg script, so it was making a .sis with the old files 🙄
The right one should be up there now.
Thanks to everyone for trying it!
Can something be done about locations that only have a 5-digit WMO index number and no ICAO code,IE: Skopje-Petrovec (13586, LWSK) ,Skopje-Zajcevrid (13588, ----).
Skopje-Zajcevrid doesn't have a ICAO code and can't be used as a location.All of them have 5-digit WMO index numbers.
Hmm...
I'm not sure. The NWS server only seems to have reports for stations with ICAO codes.
7650: the aplpication works fine!
but my problem is the connection, Im using wap settings, so i need to configure proxy!
netfront works fine with my IP, but i need to change the PORT!!!
this is something that is missing from settings tab!
besides, i liked this app
Good point.
I'll add that to the next version.
i hope u will inform us here for next version, i have some more ideas, too 😊
Does anyone want to volunteer to do a language translation?
Excellent !
Send an email to weather @ badpint.org and I'll send you the language file.
i have the greek with hexeditor, but its better with the original file
i send again, provider had problems
Jojo, I just sent you the language file.
Actually you can get it by downloading the source.
The file you want to base your translation on is inc\weather.uk.loc
Cheers,
Justin
very handy application. was working fine with my 3660. until recently.
now i always get a error message - Got unexpected response code <403>. tried with several locations but the same problem. can you help please.
have you changed anything? moved networks?
check your proxy settings are still correct.
i got it, finally!
as far as i will find time i am doing it! 😊
cheerz
ja wrote:have you changed anything? moved networks? check your proxy settings are still correct.
I am still on the same network , same location & haven't changed any of the settings. I have been using internet access (not wap) & i have no problem with other programs like the netfront browser.
ja wrote:Hi,I've just released version 0.1 of a free (GPLed) program that downloads and displays METAR weather reports on your phone. Its called "Weather" and you can get it at
Thanks,
Justin
Justin.... it is a very good tool !! :icon14: ...but what about the forecast ?... :?
