Aspicore GSM Tracker
3 replies · 1,676 views · Started 20 June 2004
Tool to track locations of Series 60 phones in an efficient SQL database. Low data costs thanks to GPRS and compact messages. Uses Bluetooth GPS or GSM network cell ID.
View the Link
doesnt work with my WAP (over gprs) connection, i think needs normal GPRS connection..
I just test gsm tracker.
it Is very limited, because they have the server and i havent control about my positions.. i dont like it.
You only connect to their server and send them the position.. 😞 Then you can consult in their web.
I prefer the new version of Realtrack Mobile 1.1. In this version no GPRS is needed becouse it is posible store a file log, and then transfer to PC.
In Addition, Realtrack give you the Server and you have all control about it.
You have the database and it posible generate tracks..etc.. and share!
yeah, u r rite! realtrack rocks!!! i was waiting for their next release!!!
i hope in future they will support MAP/gif sharing/downloading from a server
or from their web site so we will not need gps to get a map to our phones 😉
