Hi
When installing larger applications on my phone I run out of internal memory.
How does one avoid this?
cheers
Brian
Hi
cheers
Brian
Installing them on a memory card (SD/MMC)....
@ Brian a920
Go through your apps and choose the ones that you use. The ones you don't use delete
@Delta737
Unfortunately the A920/5 in standard setup will only let you install apps on the c:
Even if you put the app on the memory card once you click install it loads the app onto the c:
916 wrote:@ Brian a920
Go through your apps and choose the ones that you use. The ones you don't use delete@Delta737
Some1 know some mode for change this limit If i want install something on external memory can ido it?
on my nokia is the installation program do it why MOTOROLA is FUCK!!!!!????
do you konw modify for this problem?
bye
