I have Screen Saver 1.51 installed and WorldClock Pro 1.20
I installed an old program I downloaded Extended Recorder 1.32 and my other 2 programs when opened now gives a system error error.
Why did this happen? These are 3 Psiloc products, why are they conflicting with each other?
Here I go answering my own question, but for those who could benefit, I hope this works for you as well.
What i did was delete the Folder of the two apps after uninstalling erecorder. Ive tried uninstalling the 2 other progs but it says, function not supported or something, So i resorted to a more unrecommended way of deleting the folders of the 2programs without uninstalling.
Went on with the installation of Ssaver and worldclockpro, then it worked fine again, though i never installed erecorder again.
I think psilocs products often conflicts with each other. Will not use erecorder again.
lol .. i had teh extended profile and IR remote softwares .. they clashed too .. guess they DO have a conflict issue ... :S
Cheerz
Can anyone come up with a list of psiloc products and theyr version that doesnt conflict with each other? I have Ssaver 1.15 and world clock pro 1.2 they work fine.
Kamalayan wrote:Can anyone come up with a list of psiloc products and theyr version that doesnt conflict with each other? I have Ssaver 1.15 and world clock pro 1.2 they work fine.
It is always better when you download newest versions from our site: www.psiloc.com. When you're using an old version of one application, and download a new version of other one, it may cause a problem.
Psiloc Tech wrote:It is always better when you download newest versions from our site: www.psiloc.com. When you're using an old version of one application, and download a new version of other one, it may cause a problem.
Are updates free or you would have to buy another version of the existing psiloc product?
Because if thats the case then you should sell it in customable packages or bundles so that no program would conflict with each other.
Kamalayan wrote:Are updates free or you would have to buy another version of the existing psiloc product?Because if thats the case then you should sell it in packages or bundles so that no program would conflict with each other.
If you look on our site, you can see that we offer some applications as 'Suite'. If you have purchased our application once, you do not have to pay for a new version - unless you change your phone.
Psiloc Tech wrote:If you look on our site, you can see that we offer some applications as 'Suite'. If you have purchased our application once, you do not have to pay for a new version - unless you change your phone.
Thats great! Thanks. Good to have you in here tech guy.
