So serius problem ,
i just sending .wav file from my notebook via infrared that sending file to messages i check this out
at first i can open that file , it's work and can play it
but after i exit messages i can't go in messages box again
it show System error every times i try to open it
but all other program still works good
plz help , how could i do T-T
I'm getting really tired of my SX1. I have the same problem as you however it is not the message box but several other menus that I can't enter. I've tried almost everything (hard reset, reboot, software update a second time etc.) but it doesn't help.
Are you running with firmware v.10 as well? Maybe this could be the problem?
I'm getting VERY VERY tired of this phone. Earlier it "only" froze a few times a day, thats bad enough, but now i'm unable to use GPRS, WAP and MMS because of this strange "system error"...
Well i'm using my SX1 all the time including bleutooth to schare info and never had this problem, it din't even freeze onetime.
Try flashing to FW12, maybe it will solve your problem.
i have the same problem and when i go to flashing it by v12 the program cannot find my sub
[QUOTE="SX1 FAQ"]
Q:How can I update the firmware in my phone? A: There are two ways. A.Go to your nearest SSC(Siemens Service Center) and ask them for it. This is the only way to get the latest firmware. B.Go to www.my-siemens.com and download the latest uploaded firmware( be sure to download the correct one - check by typing *#06# and then right softkey,then checkout the "Variant Name" to see which file to download).
*SELF UPDATE INSTRUCTIONS*
a.be sure that your battery is fully charged, and that no other applications are running on your PC
b.turn off your phone
c.Press inside the joystick while turning on the phone
d.By now you'll have a screen on your phone displaying "SX1 Software Update Connect USB cable and start update software on PC."
e.Connect the phone to the PC
f.Execute the downloaded file
g.Windows will ask for a driver. You can find the driver in the folder of the updater(eg. if the updater is c:\downloads\SX1_GREECE-TURKEY-RETAIL-uk-el-tr_06_0001_update.exe then the drivers are in c:\downloads)
h.The firmware update will take some time (about 15 minutes). It is divided into 4 parts. After finishing, the phone will turn off. DON"T DO ANYTHING TO INTERUPT THE WHOLE PROCESS (like unpluging the phone, turning off the phone, shutting down the updater, etc) OR YOU MAY END UP WITH A DEAD PHONE[/QUOTE]
Hi jeno,
I have the same problem than you.
My bluetooth was working fine before.
But now I got "system error" message everytime I open this application.
Did you get information on how to solve this probelm????
hi guys today i tried to turn on my sx1 and it didnt worked after trying a lot i managed to turn it on when i tried to go to the menu and i tried to open an application and i received a message "SYSTEM ERROR" this happened with all files and apps everything that i installed and i stored as deleted <<i use fw12 >>
PLEASE HELPPPPPPPPPPPPPPPPPPPPPP :frown:
i found a solution for our trouble:
- try to turn on the phone without mmc
-try to format phone memory (while you turn on it press * and #)
-upgrage your fw from www.my-siemens.com
