Hi there.
Does anyone knows if uninstalling a software leave something behind ? You know, like windows. If u uninstall something in windows you will find values in registry, files on HDD and many other stuff you don't want.
Does Nokia 3650 uses something like registry ?
Nokia 3650 behaviour
well according to my knowledge .. after uninstalling the software leaves behind a folder with an .ini file :system/apps .. its safe to delete that after uninstallation ...
dhanesh wrote:well according to my knowledge .. after uninstalling the software leaves behind a folder with an .ini file :system/apps .. its safe to delete that after uninstallation ...
I uninstalled my MOBILEGIRL just to try, but it didnt leave a folder or an ini file.
hmmm .. strange .. when i uninstall stuff it leaves behind a folder with an .ini file .. errr .. anyone else has this issue ? or do i have a problem my self .. lol
cheerz
it happens only with certain programmes
hey maybe you might wanna try using the clean up feature on efilemanager...? It generally cleans up all redundant folders on your system...it's cool. Just place the bar on the drive you wanna clean --> menu --> advance --> clean up 😉
truwitness wrote:hey maybe you might wanna try using the clean up feature on efilemanager...? It generally cleans up all redundant folders on your system...it's cool. Just place the bar on the drive you wanna clean --> menu --> advance --> clean up 😉
Well this is cool, i just hope it doesnt mess up the system. :?
well it ain't messed up mine so far 😉
yes, but it uses some kind of registry like windows ? I ask this because is just... C++ and java (from my knowledge)...
