Parts for 9210(i) ?
1 replies · 1,932 views · Started 21 June 2004
Does anybody (especially in the UK) have any of the following available to replace knackered parts (or know where I could get them from)?
- The bottom connector - black plastic with gold contact points (the plating has worn off mine)
- Silver screen surround with "NOKIA" on it for the outsde display (damaged when if fell off the car dashboard)
- Clear plastic window for the outside front display (ditto).
Parts from 9210 or 9210i should do the trick
Waiting for 9500 but need to keep 9210i running meanwhile. It's out of warranty and I don't want to spend �150 sending it to Nokia's official repairer.
Thanks in advance to anyone who can help.
Try e-bay for a dummy phone or try you local phone shop and see if you can buy the display phone, all the parts are the same. also a 9110 has the same bottom connector.
