Any Mac users syncing with their N-Gages?
6 replies · 2,966 views · Started 21 June 2004
I'm a Mac devotee, and if I get an N-Gage, I'll be synchronizing via iSync (my Mac isn't Bluetooth-enabled yet...but once I get an N-Gage, I'm going to grab the D-Link USB dongle). Anyone else using this, and run into any bugs? Also...I've got a MMC reader, so I shouldn't have any trouble just copying files to the card then plugging it into an N-Gage, right?
it's amazing how good the mac works with a ngage. just pair the device with your mac. you'll then see a actual picture of a n-gage show up in isync! it's sweet! it even supports syncn' your pictures from address book to the mac.
take the usb cable and plug in to your mac to mount your mmc. thats it. it will show up on the desktop. you dont even need the mmc reader. keep in mind this is for the first ngage. no usb port on the QD. that case you would have to use a reader.
hallfleming wrote:it's amazing how good the mac works with a ngage. just pair the device with your mac. you'll then see a actual picture of a n-gage show up in isync! it's sweet! it even supports syncn' your pictures from address book to the mac.
Bluetooth is only used for syncing, right? You can't copy files back and forth that way?
liquidcross wrote:Bluetooth is only used for syncing, right? You can't copy files back and forth that way?
u can use bluetooth file exchange on the mac.. think its under utilities to transfer files. its called bluetooth exchange. the only "problem", is that it goest to the system memory not the mmc. works like a champ though... and you can send from the ngage to the mac
hallfleming wrote:u can use bluetooth file exchange on the mac.. think its under utilities to transfer files. its called bluetooth exchange. the only "problem", is that it goest to the system memory not the mmc. works like a champ though... and you can send from the ngage to the mac
Ah, I had forgotten about that. My bad. You can send from the N-Gage's system memory directly to the MMC and vice versa, right? I seem to remember their being a utility for that in Symbian OS for some reason...
liquidcross wrote:Ah, I had forgotten about that. My bad. You can send from the N-Gage's system memory directly to the MMC and vice versa, right? I seem to remember their being a utility for that in Symbian OS for some reason...
yeah.. just use the little explorer app to move stuff...
My N-Gage QD doesn't want to sync with iSync 😞
Something in the QD keeps crashing when I try to sync 😞
