I could connect my fone to pc suite.
But now it apperas like that (attachement) in Pc Suite
i can't echange fotos or files via PC Suite nomore
what must i do to correct this error
Is there any way to "format c:" my fone?
(here goes a SS as an atachement)
Try this:
1. Uninstall PC Suite
2. Use the '6600 PC Suite reg cleaner' in order to remove registry entries
3. Restart your PC.
4. Reinstall PC Suite, connect your phone & check.
Anyway, your problem with pc suite seems not to be caused by your handset or any file on the c: drive of it but if you intend to format it for any other reason check here:
http://www.allaboutsymbian.com/forum//forum/thread/17507/
Regards,
Where do i get that Reg Cleaner??
i did a search in google and didn't find anything....
DeLiK wrote:Where do i get that Reg Cleaner??i did a search in google and didn't find anything....
Got one Nokia Registry cleaner here:
http://downloads.nokiausa.com/pcsuite/NokiaRegisterClean.exe
i'm going to try it now
Reebooting
I tryed with the registry cleaner "uninstall reboot, clean registry, reboot, install reboot, conect fone nun 😞"
I also made a back up of 6600 and formated it using the 3 key combo.
and also nothing....
i guess the only solution is formating pc some other time... , after the exams...
tnks for the "tutorial" but it didn't wprk..
any other ideas?
PS: manual registry cleaning?
Wirelessly posted (Nokia6600/1.0 (4.09.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Of course on Nokia's support page for 6600...
