hi can anybody help how to remove the installation log from manager in nokia 6600 as i want to download the same application again....
at present i can download but the application is cannot run its expired.
pls can somebody help....
remove log from nokia 6600
ravin wrote:hi can anybody help how to remove the installation log from manager in nokia 6600 as i want to download the same application again....
Go to C:/system/install with a file explorer and delete install.log
Or, if you like it so much, buy it.
haha N/A so blunt but so true
if u able to delete the installation log then also u cannot use the same appliction
u better have to but that particular program then only u would able to run it.
Vicky wrote:if u able to delete the installation log then also u cannot use the same applictionu better have to but that particular program then only u would able to run it.
are u sure.....
elton wrote:Go to C:/system/install with a file explorer and delete install.log😊
SORRY DONT GET U WHY "C'' DRIVE ON THE PC WHEN THE LOG IS IN THE HP....
AND THAT I HAVE NO CABLE JUST BLUETOOTH....
RGDS
ravin wrote:SORRY DONT GET U WHY "C'' DRIVE ON THE PC WHEN THE LOG IS IN THE HP....
RGDS
he means the C drive on the phone , search it with fexplorer
search the formum for a free download
y dont you just buy the game anyway instead of being so tite on the developers
littledude wrote:he means the C drive on the phone , search it with fexplorer
search the formum for a free downloady dont you just buy the game anyway instead of being so tite on the developers
Hey dude, its not games i am interested in the applications....
tks anyway...
