Sync info wanted.....
6 replies · 2,653 views · Started 22 June 2004
[FONT=Comic Sans MS]any clue how to sync with MS Exchange Server for total data ? [e-mails, contacts, calendar...]
I know about IMAP and POP3 but this is only for e-mails. Furthermore I found applications to Sync Contacts and Calendar (like SyncWise) but not a combo solution yet....
any help is welcome [how about Sync ML?].[/FONT]
Hi there,
i think, there will be the way over the Exchange Client such as Outlook and Entourage to Sync with the device. When you just use the Exchange Folders as Standard and no additional .PST File, it would be possible. At the Apple Side, use Gobetween to Sync between Entourage and ICal/Adressbook. But there will be no support for stickies and Kategories.
Mike
kkostas wrote:[FONT=Comic Sans MS]any clue how to sync with MS Exchange Server for total data ? [e-mails, contacts, calendar...]
[FONT=Comic Sans MS]Sorry I didn't mention that I want to do it wirelessly (most probably over GPRS....) so a client (if I understood correctly u mean through a connection to a client PC) won't help. Thanx anyway.[/FONT]
You need to set up:
1: IMAP4/POP3 + SMTP access for email
2: A SyncML Server connected to your Exchange server for calendar/contacts synchronization
N/A wrote:You need to set up:
[FONT=Comic Sans MS]1: IMAP4/POP3 + SMTP access for email
Any Synch ML server in mind? I would like any recommendation.....[/FONT]
Check out the free beta from SEVEN. I've been pretty happy with it.
They are still offering a free beta of SEVEN Personal Edition which does push email for the P900 for Exchange, Domino, IMAP and pop email.
Check out the program info:
http://www.seven.com/Products/Individuals/Personal_Edition/Beta.html
BTW Sprint Business Connection is SEVEN. O2 xmail and Orange Office Freedom are SEVEN as well....
Looks like there is an enterprise program too - not sure what you need to do to get into that though...
