Lost Men� Item "Keyboard Lock" in Phone Mode
3 replies · 2,176 views · Started 22 June 2004
Hi there, i have a very strange Problem:
When in Phone Mode, always when you press the Option Button on the Flip, the first point will be the "Lock Keyboard On/Off Toggle". It disapeared at my SE P900!!!! The No.1 Button is now "Silent Mode On/OFF"
I installed a few themes, but i deleted them, now the Men� works when i restore the settings to the Manufacturing-ones. But when i make a complete restore, it disapears.
I am not willing to make a full reset, because with the Apple ISYNC (i use) a whole of manual customizing will be disapearing. I called SE, but the 1st Level Support was bad. The told me to make a Firmwareupdate to a version, which will never shows up on the Updatehomepage (After 4 hours of research i know it is because i have a branded phone from T-Mobile - The Support of SE was not able to tell me that!"
So is there an XML Template or something in the Phone System Folder to change to solve the Problem? Does anybody knows about similar Problems?
Thanks, Mike
It is like Magic, after a second restore from previous backup (I did a reset, a complete Sync with Apple ISync, and then a second reset with restore from a backup on PC), another Men�point disappeared. I don�t know which, i just have:
1. Silent Mode On/Off
2. Calllist
3. Call Volume
4. Status
5. Callrouting
# Applications
(The Translation may not be correct, my men� is in German)
murmansk wrote:Hi there, i have a very strange Problem:
Thanks, Mike
The keylock function disappears when the phone is plugged into the charger (either directly or via the synch-cradle).
If this error would be present only when i plug in the charger, i would propably
never recognised it.
No, this Men� Items disapeared permanently from the Option Men�.
I don�t know why,
Mike
Bassey wrote:The keylock function disappears when the phone is plugged into the charger (either directly or via the synch-cradle).
