Hiya! As you see from my post count I`m a supernoob, but I would like to know is it "normal" to recieve many connection and data errors in certain symbian apps... Like for example: One of the primary purpouses when I bought this was to use Symbian PuTTy with n-gage, so I transferred that .sis file to root of my phone with usb cable, and then installed it... It started and created key for ssh, I set the address, username and port and stuff like that. Then I pressed connect... It either said already some error (-2) or (-3) depending if I used dns. But sometimes it went through till it asked me username and password, so I put my server login there. Then it either said connected and shut whole program giving me data error or it said just connection error (-34). I know many people who use putty under n-gage with great success... I have done *#7370# few time because some 3rd party software hanged whole phone, can it break something if I do *#7370# several times? Should I go to Nokias service place to upgrade/repair my phones software? Any ideas/help will be appreciated! Thanks 😊
P.S I can use wap with same settings I use with PuTTy
