Please read & help series 60
11 replies · 2,359 views · Started 23 June 2004
my problem is that ever since i restore my phone to factory settings because my application menu keep saying 'system error' i haave some few problems im wonderin' how come when i open my manager menu on my 3660 my symbian applications doesn't show up i really like to delete some but everytime i do it it says no data but i have symbian applications. my phone totally messed up so im hopin someone can help me also everytime i download stuff from the wap site and store it on my phone memory i will say cannot install eventhough i have lots of free memory yet i can store by using my memory card? any knowledge thanks i appreciate all your help in advance.
use the code *#7370# resets the Phone Memory (like Formatting a disk) .. try doing this and hopefully things mite improve .. install other apps again on ur phone memory n check ..
cheerz
I have a similar problem ... everytime I try to acces the application control app I receive a system error. Everytime I try to install a .sis file I copied to the phone and try to install it, I gives an error too. Same error when I try to acces the phone memories system folder with FExplorer. Will restoring my phone to the factory settings solve this problem ? Will it erase my contacts list and my sms messages when I reset the phone memory or restore to factory sett. ?
nime wrote:I have a similar problem ... everytime I try to acces the application control app I receive a system error. Everytime I try to install a .sis file I copied to the phone and try to install it, I gives an error too. Same error when I try to acces the phone memories system folder with FExplorer. Will restoring my phone to the factory settings solve this problem ? Will it erase my contacts list and my sms messages when I reset the phone memory or restore to factory sett. ?
Back up your contacts
Back up your configurations
Back up your images
Back up your messages
Using *#7370# SHOULD correct these errors but as suggested in previous forums, format the MMC too.
Thx, but when I try to make a backup from everything, it gives the same error, it won't work with PC suite and make a backup to the mmc doesn't work either. Is there any way I can backup this, because I really wouldn't like to loose the contacts and their thumbnails ... So if I reset the phone with that code, does the rom memory copy it's things to the phone memory ? or where does the phone memory gets it's original data ? Thx in advance
Kamalayan wrote:Back up your contacts
Back up your images
okay im not familiar with all this so how do u back up? thanks (configurations & images? or even applications.
well .. it doesnt connect with pc suit ?? or it connects but gives u sum errors ? plz give d detail ... if u wish u would wana try out Oxygen Phone Manager to do a back up if not pc suit ... 😎
mike18 wrote:okay im not familiar with all this so how do u back up? thanks (configurations & images? or even applications.
Backing up can be done on an mmc tru ur phone using the built in back up feature .. or u can use pc suit to back up contacts and images ..
for configurations like wap and gprs u can contact ur operator and ask em to send the settings again ...
as for applications .. well u would already have the .sis files on ur comp if u transfered to ur phone .. :tongue:
And for all the above u would need a Cable .. OR a bluetooth dongle .. OR an IR Dongle .. 😃
hope this answers ..
cheerz
Well, I can copy files to my phone with bluetooth and pcsuite, so it does connect, but when I try to make a backup pcsuite gives an error ... Really strange, so I guess the system folder on the flash memory is damaged ... it's really strange
hmm .. i suggest you d'load the new version of pc suit .. it has a bluetooth fix .. go to the nokia site and to ur phone specks .. and then to d;loads .. u mite find it there .. try this n check .. besides if ur mmc is damaged then i think it wouldent read the mmc at all ..
so try this out n see 😊
cheerz
Nope, I've uninstalled Pcsuite and installed the new version. I received the very same error. Is there really no other way to backup my memory ? A backup to the mmc gives a system error too ... 😞
jeez .. guess ur mmc is curropt or sumfin .. hope u tried putting a diff mmc in ur phone n backing up .. if that also fails .. therz a problem with ur phone .. but if that goes well .. then ur mmc need to be replaced ..
cheerz
Yep, a different mmc gives the same probs, even when I boot without mmc the problem remains ... :s
