7650 Ringtones from pc help!!!
3 replies · 1,418 views · Started 25 September 2002
hi,
does anyone know how to upload the ringtones from the pc to the nokia 7650,what software do i need,i have a m620 infrared device and have pc suite that came with the phone.do they have to be converted first?only just got the phone so please bare with me....THANKS.
sandman. :-?
enable infra red on the 7650, aim 7650 at the m620 and if using xp or win200 you will be able to select the ringtone (midi or wav) via right click and send to nearby computer. 7650 will alert you as a message has been recieved, open message and save the ringtome and you will be able to select it from personalising your profile
not sure what you do in me or win 98
use bluetooth connectivity device, like the MSI BT key.
Click right My Bluetooth Places -> connect Bluetooth Serial Port -> Connect.
Then click and drag any midi or wav file in your Public Folder, your phone will beep as if you have a new msg. Save the file and your will recv' a new ringertone.
Very easy and simple
On Win98 ???
I dont get any shareable folder ...
And DO I NEED THE PC SUITE to transfer SIS files too ?? Or is it only for contacts ??
