File transfer problem
5 replies · 3,153 views · Started 23 June 2004
I have the nokia 6600 and have everything connected fine and dandy. The problem I am having is with nokia pc suite (6600) . With file transfer if I try to transfer any file to my phone it comes up with the transfer window but does not do anything and after a while a message comes up saying "Pc suite was unable to copy because an unexpected error has occurred" . I've tried copying a 10mb file, a 324k file and a 64 k file and none transfer. Any ideas on what the problem is? Thanks in advance.
I had this exact same problem. Which bluetooth driver software are you using etc.
The way that i fixed it was by using drivers that werent the ones i was provided with and starting over. Now i can transfer both from pc to phone and phone to pc.
Do a google search on Jons Bluetooth Guide, thats what i used to get mine to work
It's possibly your firewall. Try making sure it's off. If it isn't, then turn it off and try. If it works then you need to somehow open the bluetooth port on your firewall (IIRC it's 3004. I also would turn on windows file sharing 139 for good measure. Also, since it's ftp you get a large range: 20-21 or something is the lower default.
Thankyou for all your help. Much appreciated. I ended up using the different drivers and now it works how I need it to. Once again thank you very much for your assistance!
