Okay, I just reformatted my 3650 because it's got so much garbage on it and it was starting to get slow. So it restarts, and when it comes back up, it gave me something about a MailInit failure then shows the time and date settings box, I go through them, and then the phone's desktop comes up. I press menu, and nothing comes up. I press Camera and get System Error, same with Favorites and recent outgoing calls. I can still make outgoing calls, but can't do anything else. The entire phone control panel is gone, the messaging is gone. It's like buying a $5.00 phone at K-Mart. Any ideas would be helpful 😊
Format Problem
Solved, more or less. There's something on my MMC that's mucking things up... guess I'll plug it into a card reader later and clear it... strange.
Ashe wrote:Solved, more or less. There's something on my MMC that's mucking things up... guess I'll plug it into a card reader later and clear it... strange.
Thats why probably people suggest you format both the MMC and the phone.
