Bluetooth and PC Suite
4 replies · 2,622 views · Started 24 June 2004
I recently bought a USB Bluetooth adapter, (made by W-Link if that helps!
Model Number UBT1000)
I installed PC Suite, connected the bluetooth to usb, enabled bluetooth on the gage, then i start up the suite and it says this is the 1st time u have started blah please connect the n gage to the pc the continue.
So what do i have to do?
Thanks.
merther02 wrote:Hi,
Thanks.
Search the forum for info on connecting standard N-Gage.
You need to tell mRouter which com port the Serial Port Profile has been allocated to. Then connect to the serial port of the phone via the BT software.
merther02 wrote:I searched, no luck. All that came up was some shitty chat thing.
Please tell me how to do it!!! 😊
Hi, I just got mine yesterday so I dont know a lot but I had exactly the same problem as you, also with a USB Bluetooth.
Click the mRouter icon ini your taskbar and select 3 com ports that the ngage installed on, mine were 5, 6 & 7. Nothing much happens, now run the PC Suite an it should find the phone 😊
My Question is.....
Im not sure if this is possiblebut it would be ggreat if I could share my broadband connection with the bluettooth, thereby surfing form the phone for free?
I see my bluetooth network connection, but its disconnected.
Running XP SP2, Im ok with teh xp networking but cant see why the phone wont conect, do I need to do something?
Also, even though I can use PC Suite and file transfer etc, teh bluetooth manager stilll insists it cant find the device if i try any configurtion. Maybe an issue for a bluetooth forum but if anyone can help id be gratefull.
Legion
Why would you wan to surf with your broadband connection on your phone? If your within 30 feet of your PC, why not just use IT?
Or do you mean using the N-Gage as the modem for your PC? But that's silly too since you would be limited to GPRS speeds.
