If you have ever orderd of this site and get a txt message everyday or now and again then they are charging you �1.50 per txt. I spend about �45 - �60 on txt messages a month and i have recently found ou that this daclogo place is also charging me �37.50 a month to get these pointless messages. If you are in the same situation ask your service provider (vodafone) to check the messages that you are sending and then call this number, 08707502929 and this one aswell just to make sure 08448880076.
By the way it is against the law for them to not stop the service if any problems consolt a lawyer. Cheers Yourmum90
Yourmum90 wrote:If you have ever orderd of this site and get a txt message everyday or now and again then they are charging you �1.50 per txt. I spend about �45 - �60 on txt messages a month and i have recently found ou that this daclogo place is also charging me �37.50 a month to get these pointless messages. If you are in the same situation ask your service provider (vodafone) to check the messages that you are sending and then call this number, 08707502929 and this one aswell just to make sure 08448880076.By the way it is against the law for them to not stop the service if any problems consolt a lawyer. Cheers Yourmum90
You can get software for Series 60 that stops unsolicited text messages from reaching your phone so they go underlivered and thefore aren't charged to your bill.
Rather than pay �37.50, just spend a few $ on that software and your sorted.
