er...may i know 6600 izit cant send ringing tone?
i use ring tone studio send tone thr mms...my friend receive e mms but cant open e file...as e file is in amr. format...
may i know muz use wt application 2 send ringing tone?
ringing tone
woaini wrote:er...may i know 6600 izit cant send ringing tone?
i use Seleq file manager, u can send ringing tones ,may it be mono,poly,wav or true..buy you gota buy it..
Or use FExplorer (which is free) and move the file into your sounds directory. But it should be able to be opened straight from the inbox into the recorder application.
