Installing an .app file?
2 replies · 1,398 views · Started 27 June 2004
How do I do this?
I have sent it by bluetooth but it comes in a txt message and wont let me get it into the file explorer to copy and paste it! Can anybody help/
i dont get your problem. Did you transfer it using the PC suite or simply by right clicking on it and selecting the blue tooth option. It can come as a text message only when you do it the second way. In this case open any explorer like Fexplorer or seleq and go to c:/system/Mail and in this folder search all the folders and sub folders. where a message file is recorded in this folder cannot be found. so you will have to search the whole folder. You will definitly find it there then copy paste it if you want.
Why are you installing it this way? The only way files should be installed is by sis file, unless this is a warez fix, in which case you shouldn't be asking about it here.
