yewnes
3 replies · 1,677 views · Started 28 June 2004
I have installed the demo of yewnes on my n gage...How I can install the roms?? On the help there's this path e:\yewsoft\newsroms....but when I install the emulator this path is not create. Please help me.
Yes sent the roms to your device and open then from the inbox,they will be transfered to the correct directory.If you are using a card reader or USB just create the dir.
GhostDog wrote:Yes sent the roms to your device and open then from the inbox,they will be transfered to the correct directory.If you are using a card reader or USB just create the dir.
I created the path in e:\yewsoft\newsrom...but the emulator recognize 0/0 roms. I locate the path in e:\system\apps\yewsoft\newsoroms....NOTHING! HEEELLLPPP
The path is e:\yewsoft\nesroms\
YewNes doesn't have support for zipped romes so they need to have .NES extension.
