Yeah! AMAZING MP3 sound too!!!
3 replies · 4,990 views · Started 28 June 2004
Hi!..
just to share my test about mp3 playing on 7610...
I tested a very good quality playing even with 160kbits 44.1 khz stereo mp3s...
no lagg non stop... on the default nokia recorder player puting the files on
E:/nokia/sounds/digital/ ...
Then i created a few MP3 ringtones converting some songs to a 128kbits 44.1 khz. mono mp3s 😃 ...
The sound quality on the speaker it's really good, just setup the ringtone volume above the first half...
Here you can download my MP3 ringtones tests: 😃
AEFox MP3 Ringtones
Remember to put on E:/nokia/sounds/digital ... using the PC Suite file browser ... in order to see them on the phone ringtones list
hope you like it!
cya!
However what do you do if you have windows 98 se,therefore the pc suite and usb are not compatible, can't transfer mp3 files or wma as nokia can't read them ,does anyone know another way please.
Cheers
Hi aeofox I'm trying to make my own mp3 ringtones as well were do you change this ringtone volume (do you mean the phone or on the desktop)?
