[FONT=Arial Black]undefined[/FONT]undefinedHi i was wondering if you can create your own themes because i have seen alot of people who have made their own themes and id like to make my own so if ne1 can help me i wil b grateful. thanks
Does ne1 know how to crete your own themes?
Sign up (it is free) to http://forum.nokia.com, find the "Series 60 Theme Studio", download, install & run.
when i tried to install it on normal powerful win xp pc it said your config is no good and aborted??? anybody else with same problem? any solution?
btw this was with version before the most recent one i think...
ntn wrote:when i tried to install it on normal powerful win xp pc it said your config is no good and aborted??? anybody else with same problem? any solution?
Make sure you are using the latest version.
The first one wasn't offically XP compatible.
And if you have to older release, then just set the compatibility to "Windows 2000" (Explorer -> select inst file -> right click -> Properties -> Compatibility).
i have a " Installer User Interface Mode Not Supported" error message!
HELP!
thanks evry1 for their help. startin to make mi own, takes time lol. thanks
