Can you help me to explain this problem with my duo ?
2 replies · 2,050 views · Started 28 June 2004
Hi guys and girls. I just bought a 64 mb memory stick duo, the problem is whenever I try to save something on it I just receive a "disk corrupt" message, I can't even reformate the memory stick duo, I always receive the same message "disk corrupt". Moreover, the phone doesn't give the chance to save anything on it and just give me the option of the internal storage; funny thing is than the same happens with the original stick (16mb).
I can see some "scratches" on the surface of the metalic "connections" in the two cards....Is it some physichal damage on the cards or some problem with the file manager system in the phone that causing the whole situation ?
Thanks in advance and please excuse my spelling and grammar.
The problem is in your self phone.
Have you got your warranty?????
Ok, the problem has been solved, I just turn off the phone and then turn it on again about three times. Now everything is working fine, thanks.
