My HQ Video Test :)
2 replies · 5,427 views · Started 29 June 2004
Hi!...
After a lot of encoding tests ... i found a good balance between the Video Bit rate and the Audio Bit Rate and Sampling rate ...
If you want a perfect Video quality you must sacrifice audio quality a little bit to get a nice fluid smooth (non stop or lagg) 15 fps and less compressed (less pixelated) image quality.
176 x 144, 3GP Mpeg-4: 160kbits and Audio codec (ACC-LC Music) at 24kbits 16khz mono
But if you want a good Audio and still very good video you can use same codecs but 144kbits for video and Audio 32kbits 32 khz mono
For a very complex or many action video FullScreen you can use 144kbits on video and 24kbits 16 khz for audio to keep the best quality for smoother video with no lagg..
Here you can DOWNLOAD my test, a very nice quality video using those parametters.
AEFox Video Test (Extract from a BWM film)
Hope you enjoy it like i did 😃
cya!
Hey AEFOX, I've downloaded your MP3 ring tones and they sounded perfect! thanks.
By the way, can I ask you what do you think are the optimal parameters to be set for converting my CD music to the mp3 files to be played on the 7610? Someone in the forum said, if the sounds are recorded above 44Khz or the bitrate is higher than 32, it sounds quieter. Is it true? what is your recommended bit rate and sampling rates?
I've tried different ways, and cannot come to a definite conclusion myself.
CP
cpwonghkg wrote:Hey AEFOX, I've downloaded your MP3 ring tones and they sounded perfect! thanks.
CP
Hi!..
I think that the same parameters that i used for that ringtones work perfect for music listening too... you actually can ear that ringtones on a PC WinAmp for example and sound perfect... the parameters are 16bits 128kbits 44.1khz. Mono. ... No lagg ... non stop... sounds great!
cya!
